fefepeto_kb
Class controls and indicators shall default to "this" class
Status: New
It's hard to believe that this is the first post to request something like this (pun intended), but I couldn't find it after a few queries.
The base idea would be that both the static and dynamic connectors used to connect the methods to the owning class shall be defaulting to the owner class, a.k.a. this object in text based languages. The main problem is the use case for refactoring. When moving around methods the class controls and indicators have to be replaced every time. It doesn't matter if I'm moving methods between classes or to interfaces it is the same pain: replace the connectors (with QuickDrop), then change the names to class names, then update the icon, finally move the VI to the new location.
I know that this could and maybe is already solved with scripting, but I think the development environment shall grant the option to change the control and indicator to this object that will always default to the owning class, without manual updates. Even the labels could be This in and This out, and replaced in real time with the actual class implementation on the block diagram of the calling VIs.
The proposed solution would also get rid of the error telling about the dynamic dispatch controls shall reference the owning class, since it would happen automatically.
2 Comments
Intaris
Proven Zealot
I kind of agree, but in the meantime there's a quick-drop plugin that does some similar things.
https://lavag.org/files/file/132-lvoop-assistant/
While your specific use case is not covered, it might be feasible to make changes to this code to add your desired functionality. I use these kinds of plugins regularly, it makes using LabVIEW considerably easier.
Quiztus2
Active Participant
I agree, would have been the better design decision.
Actor Framework
