4 | |
4 | |
3 | |
3 | |
3 |
Excuse me if it has been already proposed.
In many cases I don't use the Cleanup diagram feature instead I would clean the code manually. In those cases its time taking to check for the bend wires so it would be good to have an option along with the cleanup diagram feature to have only to remove the broken wires, Clean up the bend wires like that. If the VI doesn't have a Breakpoint for example that can be disabled and whatever applicable can be enabled. Here is what I propose
I guess this can be extended with other usefull options also.
