| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
When doing UI work, it can be quite frustrating rewiring hidden controls to the connector pane. You have to go to the block diagram -> Show Control -> go to front panel and wire it up then hide your control again.
I have seen a number of ideas proposing ideas such as hidden controls always being visible in edit mode or being able to link block diagram controls to the connector pane which I agree with and would also solve this.
My suggestion is that when you select the Wiring Tool on the front panel or click on the connector pane (to wire up a terminal) all the hidden controls would become partially visible and become connectable to the connector pane.
