| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
Please add to the right-click Cluster popup menu a Remove Cluster item analogous to a tab control's Remove Tab Control removes the parent container and leaves the contents as-is.
