 beuvink
			 on
		05-09-2022
		09:06 AM
			2 Comments (2 New)
			beuvink
			 on
		05-09-2022
		09:06 AM
			2 Comments (2 New)
		In vi.lib\Utility\file.llb the 'file open+.vi' throws an error when a file can't be opened. It doesn't tell which file it can't open.
One of the strenghts of LV is the source string in the error cluster that can be used to include a lot of extra information. For example which file couldn't be opened.
The change can be very simple, just add the file into the source string, also see attached file:
This is probably true for some other files here as well.
(also checking out these files... would be nice if they are updated to some newer standards... still some very old styling here...)
Some background: https://forums.ni.com/t5/LabVIEW/Looking-for-feedback-on-the-Carya-PDF-toolkit/m-p/4229342#M1228046
