11 | |
8 | |
3 | |
3 | |
2 |
Currently, we have to use Unbundle By Name from Cluster and select an element for Case Section
It would be great if we could just wire the Cluster Directly and have a Right-Click Option at Case selector to select an element (one element only).
P.S. If it is a reasonable suggestion and gets enough Kudos to get R & D team’s attention for feasibility of this idea, then we ask for more logical operators support that would be useful. Also multiple elements and/or more statement node i.e. (type == Array and # elements <= 2)!!!
Only sometime I miss “if statement” support in LabVIEW.
