5 | |
4 | |
3 | |
3 | |
3 |
I find that there are WAY too many steps to setting up a custom button with up, down and hover graphics. And there is too little documentation on this subject as well. Here are the steps I have to use to build a simple button from 3 basic png files (for the 3 states):
• Drop System button on front panel
• Right click menu > Advanced > Customize button.
• From control editor, choose customize mode.
• From the right click menu on the button:
1. Import from File
2. Select normal button image.
3. Copy to Clipboard
4. Select third picture item
5. Import Picture From Clipboard.
6. Select second picture item
7. Import from File
8. Select ‘down’ button image.
9. Copy to Clipboard
10. Select fourth picture item
11. Import Picture From Clipboard.
12. Select sixth picture item
13. Import Picture From Clipboard.
14. Select fifth picture item
15. Import from File
16. Select ‘hover’ button image.
• Change back to edit mode.
• Save control.
There has to be a better way!
