7 | |
6 | |
2 | |
2 | |
2 |
I would like to be able to collapse code so that it looks like a sub vi but is part of the main vi as if it was not represented as a icon. Double click to edit it like a vi. Options to convert it to a real vi. This would be useful for glue logic, being able to build and share more complex functions without a lot of subvi's. Decrease cross linking of VI's and naming problems. Attibute nodes and locals could be used inside ot them without passing a reference. Would make source code control simpler.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
