So, I've recently transitioned portions of our code to LabView OOP. There really doesn't seem to be a feature which is equivalent to llbs in terms of how we use them, so I'm forced to build and release specific library .llbs for each class which uses dynamic dispatching.
There are numerous annoyances with this, but one of the biggest is the severe reduction in the utility of the Compare Hierarchies functionality. Now, I get a all kinds of VIs which show up as "x", i.e. different, which when I pull them up show no differences at all (I always filter to show only noncosmetic block diagram changes, because who cares about anything else, really).
Also, pretty much every version I get a raft of results where the only change is the path of a library/class dependency. Also, nobody cares. There should be a generation option of exclude VI path changes.
