| User | Kudos |
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Hello, this is my first post in this forum and I don't found ideas about this topic. I hope you like it.
Well, time ago I started to work with LabVIEW, It's powerful, but there are some kind of issues that I want to explain here. Now I'm get involved in a big project for a very big aerospace company, and I'm developing a complex application to acquire some data and process it. Well, this software is in development by some people and I have an idea for the work flow.
I explain it with an example:
If we have in every VI a little data base with some notes ordered by type or something we can read the code or we can start to work in a VI faster. Imagine that you have an event structure with several cases, and you put some notes like you can see in the following image:
Now, I'm able to revise quickly the code reading all the notes and start working only in the "TO DO" zone. But let's do a more complex design: Now I open my project explorer, and open the "Note manager" that could be like this.
Here it is the real advantage of this tool: All the design are done and now I want to improve the application. Lets go only to the notes that interest to me: "TO DO" notes. If I double click on an element LabVIEW opens for me the VI centered in the zone that is interesting for me. And some more: I can check the work I've done and I can add new notes only with a click.
The more complex the project is, the more useful is this system. So, what do you think?
Available in LabVIEW 2013 and later. Launch the Bookmark Manager, available in the 'View' pull-down menu, to use this feature. Any diagram label containing a #hashtag will appear in the Bookmark Manager.
