Picture says it all.
I am not allergic to Kudos, in fact I love Kudos.
Make your LabVIEW experience more CONVENIENT.
Not exactly, has ATSS is not an extensible node, so you have to bundle into array first.
If anything, the format into string would be the closest option I could think of:
...which was in the OP!
I think we have to make sure an idea works for many users and use cases. So clearly the possibilty to insert LFs is not enough.
The idea should actually be to have an optional string input as the delimiter (defaulting to the empty string to be compatible with existing code).
But of course this would all just be shorthand for this:
