If you remove the default selection View As Icon for all the control and indicator, it is good for the programmer for easy to visualize the Block diagram code.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Default-Option-Do-NOT-Place-Front-Panel-Terminal-as-Ic...
