Yamaeda
Upper bundle output
Status: Declined
More often than not, i "pull down" a bundle by name, do something and then want the wire to continue at the same level from whence it came. With the centered output this requires some fiddling and Clean up wire only helps half way. If the Bundle function had an output at top, like it's cluster definition, it'd work much better.
/Y
Qestit Systems
Certified-LabVIEW-Developer
7 Comments
fabric
Active Participant
I think the problem with your use case is not the location of the output terminal's anchor point, but rather that it favours the "rightward" direction. I'd much rather that the bundle node grew such that wire bends at the output are minimised, and often that will mean the output wire exits at the top or bottom or the node.
I don't want the anchor point moved as you suggest, but I do often want my wires to exit from the top or bottom when I resize the node, so kudos 🙂
Yamaeda
Proven Zealot
Actually i dont want i moved, i realize some might prefer the current way, but an extra output at top (and as you mention bottom) would help.
/Y
Qestit Systems
JB
Trusted Enthusiast
Trusted Enthusiast
About 5 years ago, I posted a similar idea for Merge Errors.
Yamaeda
Proven Zealot
 And i've liked it JB: 🙂
Qestit Systems
LukeASomers
You can already send the wire straight up. Do you just want the arrow to point up?
jcarmody
Trusted Enthusiast
Before:
Script (suitable for Quick Drop):
After:
I need to test this, but I'd use this as a QD because I do this all the time in the JKI State Machine.
Jim
Darren
Proven Zealot
Status changed to: Declined
