The idea is that a single conditional statement could overlap a for loop (or while loop) boundary. I don't know exactly how to enable the feature in the block diagram but it seems like it could be very useful when you have routines that are different for each case that run both outside and inside the loop passing data between them (see example block diagram). This can be done right now with two conditional structures but it is just not as clean a solution.
