5 | |
4 | |
3 | |
3 | |
3 |
I often need to count how many times a condition is verified inside a loop. The simplest way to do so is:
What about this?
The "conditional terminal" should be enabled by right clicking on the operator, and may apply to every VI with 1-1 I/O pattern.
Of course it performs the operation in case of "TRUE", and leaves its input value unchanged in case of "FALSE"
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
