6 | |
6 | |
3 | |
2 | |
2 |
When working with LVOOP we can define private and protected methods which can only be called under certain conditions.
Currently LV does not offer a visual indication as to which code is invalid in the current context.
A Picture from this thread shows code which is broken (Casea A and B) but it's not clear from the BD that anything is broken at all. No broken wires, no grayed out icons. OK, the run arrow is broken, but the code looks otherwise quite healthy. I would like to see either a red X over the inappropriate methods, broken wires or grayed out icons for invalid LVOOP methods.
Shane.
