In the Configure Timed Loop Dialog Box documentation we are told that:
Period—Specifies the amount of time that elapses between two subsequent iterations of the Timed Loop. The unit of the period changes depending on the timing source you select in Source Type.
But nowhere are we explicitly told what the unit of Period is. This ought to be made explicit for each of the possible Loop Timing Source Types. I'm guessing that if I select 1 kHz Clock the unit of Period is 1 millisecond. But I shouldn't have to guess!
[note: this is a cross post from the NI Discussion Forums]
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
