Current OPC UA monitor function - Add Monitored Nodes.vi - will only trigger a monitor on value change.
It would be very useful to have the possibility of monitors for timestamp changes. E.g. if the same value was writtent twice I would still like to detect this.
This is also how shared variable monitoring works.
