10 | |
3 | |
2 | |
2 | |
2 |
Unlike building a Packed Project Library, source distribution builds will succeed even if a contained VI is broken. For my use case this is undesirable - a broken VI being included in the source distribution is always user error, and I would like to be notified during the build process.
It would be helpful if the build specification for a source distribution could be configured to fail if an included VI was broken. By defaulting to false this could be added in a backwards-compatible way without breaking any existing build specifications or workflows.
I could write a post-build step that validates the VIs are not broken, but this wouldn't provide feedback until the build is complete. A native solution could abort the build early if VIs are broken.
