| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
When working on VIs that require large arrays or images for input, I often need to run a calling VI rather than the VI I'm currently working on, which involves a lot of tabbing between windows and clutter from having more open windows. I realize it is possible to set default values for controls, but I would rather avoid that as I often use optional connections to my SubVIs and therefore don't want to change default values.
In my opinion it would be useful to have the option to configure the run button to run a different VI than the currently open one, when working on VIs specifically developed to run as subVIs in the context of a higher-level caller.
