Intaris
Connector pane visual feedback
Status: Declined
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
I'm pretty sure I just deleted my originalpost with an edit:
I would like some help when wiring up a Connector Pane.
On large Monitors and less than 20/20 vision, it's easy to hit the wrong terminal.
A visual feedback as to which terminal is currently active would be of help.
As would showing a larger version when wiring allowing the user to change active terminal with the arrow keys....
Shane.
Message Edited by Intaris on 06-08-2009 06:54 AM
5 Comments
Intaris
Proven Zealot
Shane.
Intaris
Proven Zealot
My original top-level post was overwritten when posting what I thought was a clarification comment.....
Please ignore the message copy in the first comment above.
Shane.
JÞB
Knight of NI
Edit Icon has a pop-up with a large icon and a nice GUI.  Edit Connector doesn't.  I can "link-to" from any L-word variable, global, method or property node but I can't do a "Shift-drag & Drop" to the connector?  It's high time to revisit the connector pane.
Manzolli
Active Participant
Zoom have been an issue all over the LabVIEW GUI (FP, BD & CP). There are some 3rd part software that magnifies a region around the cursor. Will be nice if LabVIEW implement a tool like that 100% compatible with LabVIEW environment.
I use the free software "DesktopZoom" (http://users.telenet.be/littlegems/MySoft/DesktopZoom/Index.html).
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
Darren
Proven Zealot
Status changed to: Declined
