Hello Everyone,
it would be cool, if I could change the visibility of plots online by adding a check box for every plot to the legend. These check boxes would be used in the same way as digital displays of chart (option to show them, moving them, etc.), only that they are always inputs and default value is true.
Marc
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
