6 | |
2 | |
2 | |
1 | |
1 |
I'd like to be able to delete an object from an existing wire and then have that wire be automatically reconnected. Currently a broken wire is left after deleting something and one must manually reconnect the wire. This would be the opposite of the popup option to Insert something. Some deletions may produce a maze of broken wires that would be difficult to determine what to auto-reconnect but perhaps situations where there is only one broken wire (for example removing a Numeric Increment function (+1) from a wire) could be handled.
