Two enhancements I would like to see related to Context Help:
1) I sometimes use a control's caption to display run-time formatted text. For instance, an Elapsed Time slider might show HH::MM::SS format. Whenever a control has a caption, LabVIEW automatically uses the Caption text as the title of the description. I would like the option of being able to select Label, Caption, or None for the context help label. If None, I can format my own title for the Context Help.
2) Labview also uses the formatting style of the Label/Caption as the style of the context help label. I would like to be able to set a default style for all Context help labels so that even if my labels/captions are different font sizes or styles, the context help can be consistent. I may want to draw more attention to certain controls, but there's no need to have a huge label in the context help.
