In addition to these ideas that suggest saving FP size and position for run-time
It would be nice to have a tool to precisely control window size and scroll of the pane (not only window position). Sometimes it is hard to set them with pixel precision.
Ctrl key plugin to try (Ctrl+X) is attached. Works only with single pane VIs for now.
