11 | |
7 | |
3 | |
2 | |
2 |
Today I discovered NI has discontinued support for NI-CAN hardware (not XNET) beyond LabVIEW 2015SP1. If you want to use your code with NI-CAN hardware and LabVIEW 2016 and beyond, you are out of luck unless you have the cash to buy XNET replacements and want to rewrite your code for the XNET API.
I have a very large J1939 simulation/monitor application I wrote and have supported for the past 8 years that is used on several lab benches and by numerous software developers across the country. Now, we stuck with LV2015SP1 forever unless we can find a large amount of cash to replace all the NI-CAN hardware, which isn't going to happen anytime soon.
So, my idea is for NI to keep supporting NI-CAN in current and future versions of LabVIEW
NI-CAN support policy is outlined here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Keep-supporting-NI-CAN/idc-p/3336034#M35648
