I found this behaviour of LabVIEW some months before and till now i didn't get the answer that why am posting here.
When i have some controls in the front panel if i press ctrl key and left mouse button and drag between the controls it gets displaced. Is that a short cut key for aligning the items? or does it has any functional use?... I am really puzzled with that behaviour and no body knows the answer (the person i met) for it. If it is a strange behaviour and do not have any proper use then in the next version the architects and champs of LabVIEW can try removing the behaviour.
