As mentioned in this post, and elsewhere, it is very helpful on the forums to (1) post images and (2) post code that is usable by the masses (typically 8.6+). Snippets are a useful way to post both images and code (for 9+ officially and earlier with a few tricks like the Code Capture Tool). One downside is that if you are working in LV10 your snippet is not usable in earlier versions. It would be nice to be able to Create a Snippet for a previous version in one operation.
I do this myself, for example:
Makes life easier for both the posters and the responders on the forums.
