I misunderstood ouadji's post here, but I liked my interpretation of it. I didn't find it on the Exchange so...
Idea:
Make it possible to copy the VI properties from one VI to another.
Method:
User right-clicks on the VI in question, selects "Copy VI Properties", then right-clicks on the new VI and selects "Paste VI Properties". BAM! All (or almost all - to be discussed) properties are copied to the new VI.
Similar to JMP's Copy Column Properties:
What properties would be copied over?
Initally, I thought EVERYTHING! But then my fit of insanity passed and I realized that some items should not be copied.
The Big Two That Shouldn't Be Copied (that's like, my opinon, man...):
Revision History
Window Title
Everything else is up for debate. So go, debate away you master debators!
