LukeASomers
When placing a Diagram Disable structure, enable has 'removed' contents instead of being empty
Status: New
When placing a diagram disable structure, the 'enabled' side of the structure starts blank, and the wirethroughs are replaced with default values. I have never wanted this behavior. Every time, I want it to:
1) duplicate the disabled side to the enabled side
2) select everything in the enabled side except for the wires.
3) execute the 'remove' function I normally get by 'ctrl-space, ctrl-r' (quick drop, remove)
12 Comments
AristosQueue (NI)
NI Employee (retired)
Can you post pictures of the before and after that you'd like to see?
LukeASomers
Before:
After (disabled side of diagram disable is exactly as would be now)
Manzolli
Active Participant
Looks more intuitive for me.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
altenbach
Knight of NI
This will only work if there are matching inputs and output. In the general case there is a near infinite number of possible input/output pairings. How is LabVIEW supposed to know how to pair them up for wiring?
altenbach
Knight of NI
For example, how should the enabled case look in the following diagram?
ouadji
Trusted Enthusiast
sorry LukeASomers,    but altenbach is right    Smiley Frustrated
AristosQueue (NI)
Merely because Altenbach is right in the general case doesn't mean LV couldn't do what it could in the obvious case. "If exactly one tunnel on the left is mapped to exactly one tunnel on the right (mapped => wire passes through nodes and arrives at the far tunnel with the same original data type), then wire them. Otherwise, leave them unwired." What would be the harm in that?
LukeASomers
Altenbach, that is A) a rare case and B) would be no worse than what we have now. You're probably not going to want the default outputs, so you're going to have to manually wire it anyway!
How about we add one new twist to it: after adding the diagram disable structure, the enabled side is forward, all of the newly generated wires are selected, and the outputs all have 'default values if unwired' set. Now you're one keystroke away from the current setup.
altenbach
Knight of NI
This means that sometimes you get a wire and sometimes not, and we would need to check the enabled case anyway to make sure what it did and if we like it. Maybe it should only try to wire more obvious datatypes, such as e.g. references. Anyway, the same idea argiment could be equally applied to case- and sequence structures, which are used significantly more often. I still don't really think it is needed.
AristosQueue (NI)
Yep.
Yes on Case, no on Sequence.
