13 | |
11 | |
3 | |
3 | |
3 |
Although it's already possible to programmatically edit items in an enum or ring control using the strings[] and StringsandValues[] properties, it might be much easier and user-friendly if it were possible to directly copy and paste an array of items and values (i.e. from and Excel file) into the editor itself.
