| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
I have an evolutionary project which has many VIs and CTLs on disk which are no longer called by the project.
It would be fantastic if there were an option in the project manager to highlight or list files which are in the project but which were not called by any other component of the project.
For my application, for example, there would only be one single top-level VI and any other "parentless" VIs should be deleted from the project (or, even better, they could optionally be deleted from the filesystem).
One might even be able to compare all the components in a project with all the components in a given directory structure and highlight the differences such that unused files could be removed.
The discovery of Auto-populating Virtual Folders in the project manager was fantastic, in that I no longer had to file my VIs in the file structure AND the project, but and extension to this might be the ability to highlight files which are not called by any other VI in the project.
