Create two versions of the LabVIEW Run-Time Engine - 1 with dependencies (vi.lib, etc.) and 1 without dependencies. If a LabVIEW Run-Time Engine with dependencies were to be created, it would allow you to bypass the TestStand Deployment Utility when deploying test software created using TestStand. It would also simplify Application Builder because any native dependencies (code shipping with LabVIEW) wouldn't have to be packaged with a LabVIEW executable (only the user-created dependencies).
If maintaining two versions of the LabVIEW Run-Time Engine isn't acceptable, it would be nice to just include the dependencies in the LabVIEW Run-Time Engine. Disk space and broadband Internet connections have almost virtually eliminated the necessity for a LabVIEW Run-Time Engine with a small disk or installer footprint, particulalry when NI hardwire driver installers take up 100s or even 1000s of MB on disk.
