| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
The idea here is to have the option to create not just a constant when connecting to a property node or indicator, but instead to have an option to connect up a bundle by name with the constant connected to it. This would be invoked by the usual right click menu, but with extra options if a cluster is present. I'm not exactly sure how to handle the bundle or bundle by name, but as I am partial to the arrange horizontally arangement of a cluster, it might be nice to have the option to have the constant that is created be either horizontal or vertical, via different options in the selection menu.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
