Actualy we can select 'Use default (value) if unwired', but in many case we want only for many data to just pass thrue the stucture or to take alway a specific path. It would be usefull to create a special case, by example "Default path" were we can wire Input/ouput tunnel connection and select this case for unwired tunnels.
