In a big project I needed to insert a function at several (read "more than hundred") places.
How much would I have appreciated a history which gave me a direct access to this function without the need to go to the specific functions palette again and again !
This would have saved me a lot of time... and made this annoying task a little bit less annoying !
LabVIEW should memorize at least the last inserted function/VI but a history of four or ten would be much better.
The history could be implemented either with an extra menu (see below image) or by listing the X last inserted functions/VIs right under the All Palettes menu entry.
The incompatible functions/VIs for the wire type should be grayed out or, even better, the history should be contextual and list only the compatible functions/VIs.
