I think it would be very useful to have the create DVR, change to DVR and change from DVR shortcuts on the menu.
I already did some of this, but it shall be a built in functionality.
I also encountered a bug in the change from DVR for controls and I couldn't work them around yet. To be exact, when a control is moved out of a DVR using scripting it becomes locked and the label is made invisible. The same is not true for the same operation on the UI. The only workaround I found was to replace the created control with one of the same style. The new problem is, that enums and rings that aren't typedefs loose their item lists. Of course this could be worked around too, but there might be other types I haven't tried yet.
