| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
To begin with, this is very likely a corner case, I don't expect this to get ever implemented, but the VIs are password protected which makes customizing them difficult.
When a project with a lot of VIs is open in a LabVIEW instance the Quick Drop loads for ~2 seconds, which is more then enough for me to press the shortcut combination too, leading to another pop-up windows to appear (like find window for Ctrl+F).
I wish this would be options, i.e. another option on the customization panel, or an option inside the project file/library which might be used less frequently.
