| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 2 | |
| 2 |
Provide a new command line option to open the VI specified on the command line automatically minimized (/MIN) or hidden, i.e. just in memory (/MEM). When I want to research something in a project, I open many top-level VIs from the command line which takes a considerable amount of time. While they are loading I should be able to work on something else but LabVIEW keeps opening the windows on top of all other applications. Neither cmd.exe's start /MIN a.vi nor start /MIN LabVIEW.exe a.vi minimizes it. See current arguments here: https://www.ni.com/docs/en-US/bundle/labview/page/lvhowto/lv_defined_args.html
Consider that a related idea had 334 kudos but was declined for NI-convenience. If LabVIEW did that this wouldn't be needed: "Don't force all LabVIEW windows to the top when one is selected" - https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Don-t-force-all-LabVIEW-windows-to-the-top-when-one-i...
