Often times I need to change a property of something in labview that seems to only be available through a property node. And often I don't want to do it during run time just once at development but I find it really hard to get references to some objects and I want them in another VI that I can run real quick to set the property and then be done. If you have the option enables that shows labview scripting property node options and invoke nodes, can under create there be a Create reference in a new vi. And if you click it you get a new VI with just a ref that you can then do whatever you need with it. And please make this work for anything that has a property or method related to it. I have some tools that I wrote that can kind of do this but I am sure it is not a good way of doing it (but it is the best I have got).
