11 | |
8 | |
3 | |
3 | |
2 |
I would like to be able to format the text that goes into the name field. i.e. Bold or Underlined. Also if I could put a box around it like a boarder and be able to change the thickness of the boarder.
Here is the forum that brought up this idea.
http://forums.ni.com/t5/LabVIEW/Annotations-Overlapping/td-p/1761496
