It should be nice to add custom message to the error cluster.
When you use the codified error codes, you cannot use dynamic error messages like : "File XXXX not found !"
So it would be easier to build more "user friendly error messages" ...
An additional Timestamp would also be usefull !
Something like this ....
To bypass this, i personnaly concatenate my custom error message to the error source.
It's not terrible ... but i have no other choice ! ![]()
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
