 manu.NET
			 on
		02-11-2010
		10:56 AM
			5 Comments (5 New)
			manu.NET
			 on
		02-11-2010
		10:56 AM
			5 Comments (5 New)
		It should be nice to add new VIs in the error handling palette.
These VIs could give, without having to analyse the satus or the error code, if there is no error, an error, a warning ....
So instead of testing the Status it could be ...
I know that the error cluster can be directly wired to a conditional terminal ...
but everytime you are in front of such a diagram, you have to think of what will happen ? If i get an error the loop will stop or not ???
But using a kind of VI i describe previously ... there is no ambiguity ... it's clear !
