6 | |
6 | |
3 | |
2 | |
2 |
It should be nice to be abble to add Custom events to Xcontrol ...
I know that it is already possible ... but in a not user friendly way !
I would like to be abble to add a custom event like adding a new property or a new method.
And this "Xcontrol user event" could be seen automaticaly in the "Add new event" of an event structure, when an instance of this XControl has been drop on a front panel.
So what i would like is ...
My need is to add custom event different from "Value changed", in order to build powerfull XControl.
And be abble to use these events without having to regiter them manually. (But like standards controls and indicators)
National Instruments will not be implementing this idea. NI has no further plans to invest significantly in XControl technology.
