| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
hello forum
thanks NI for the new features in LabVIEW 2019, so far I am liking most of the things you have done; except for that 1 item, context menu change
Why change the context menu (on right-clicking wires)?
2010-2018 1..3: clean up wire, create wire branch, delete wire branch (7.1...7.3: create constant, create control, create indicator)
2019 1..3: create constant, create control, create indicator (4..6: clean up wire, create wire branch, delete wire branch)
surely NI have reasons, but can try implementing a customizable context menu as a feature instead? I used to be able to write or edit my codes with muscle memory, but now I spend more time undoing things... ![]()
maybe the next patch? ![]()
Declined for reasons listed in AristosQueue's reply
