cy...
Customizable context menu
Status: Declined
Declined for reasons listed in AristosQueue's reply
hello forum
thanks NI for the new features in LabVIEW 2019, so far I am liking most of the things you have done; except for that 1 item, context menu change
Why change the context menu (on right-clicking wires)?
2010-2018 1..3: clean up wire, create wire branch, delete wire branch (7.1...7.3: create constant, create control, create indicator)
2019 1..3: create constant, create control, create indicator (4..6: clean up wire, create wire branch, delete wire branch)
surely NI have reasons, but can try implementing a customizable context menu as a feature instead? I used to be able to write or edit my codes with muscle memory, but now I spend more time undoing things... Smiley Indifferent
maybe the next patch? Smiley Wink
CY (expired CLAD)
13 Comments
mwatkins
I am in same boat as CY, have multiple versions of LV to use and this change is making LV 2019 less efficient.  If anything was to change making this a customizable setting would be far preferable than just breaking long established behavior.
Sr Test Engineer at American Innovations - LabVIEW CLA - Kudo's are appreciated!!
Darren
Proven Zealot
If you're working with multiple LabVIEW versions, I suggest installing this right-click plugin, which will add the Create Constant/Control/Indicator items to the top of your right-click menus for wires and terminals in LV 2015-2018.
mwatkins
Thanks DNatt,
The token mentioned above by CrossRulz works for me,
thanks
