13 | |
11 | |
3 | |
3 | |
3 |
As many of us knows, the Error list window can also show warnings (if the checkmark "show warnings" is enabled). But I find that there are some warnings that could be removed. For example, after the "event structure case" introduction the "unwired front panel terminal" warning is rather common and I think it shouldn't treated as a warning, for controls (for indicators... it should be a warning). I propose to have, on labview options, for example, the possibility to select which warnings to exclude. Of course, the choice of which kind of warnings can be neglected and which not is very difficult and delicate. But a reduced waning set could help developers for a better control of their software.
What do you think about?
Thank you.
