Cut/copy/paste/paste image/send selection via email - all of the time whenever a right click is executed for any command.
I don't know if this has been discussed but this is such a common feature in most programs it goes without saying especially on the block diagram when copying text, values and LabVIEW code. I know you can hit the ctrl key and drag/copy. However, when copying text from one string to another sometimes I just want to right click and have these options available.
