Sdserlin
Speed control for the bulb
I know breakpoints can be used to speed to sections where codes issues may arise as well as retaining values, etc. However, there are times when it would be helpful to have a speed control on the bulb to speed up and slow down the speed of the code which is running especially whenever evaluating someone else's code or new architecture/projects.  This way if I need to step through the code and want to watch it run in the block diagram I can speed up or slow down the pace by which LabVIEW steps through the code. I would like a really slow mode as well as a very fast mode.
2 Comments
elset191
Active Participant
This has been suggested many times.  I think this is the original IE post.
Tim Elsey
Certified LabVIEW Architect
JordanG
NI Employee (retired)
