8 | |
6 | |
5 | |
4 | |
4 |
All time complete data logging is not necessary.
In present version if we want to log the data we have to use write function for the particular file format and we get the continuous logging facility, same time if we want the acquisition at 1 Sec and data logging after each 5 Sec we can't do it. We have to write one code to achieve this logging target. So same time if logging time selection option is there in File Write function this can give us the freedom to do data logging as per our application requirement.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
